1VC JÁ VIU NEGATIVO BATERIA,SEU ATERRAMENTO,MOTOR CHASSIS,CAMBIO CHASSIS,TESTOU A BATERIA E ALTERNADOR.,PARADO E NA PARTIDA ,CONSUMO CARGA ?PONTOS BASICOS,ANTES DE SE APROFUNDAR,CONECTOR DO PAINEL ESTA OK,DO PEDAL ACELERADOR,OK ?
ESTE CARRO SOFREU ALGUMA AVARIA ( BATIDA ),FOI LAVADO ?TEM UM HISTORICO?FOI INSTALADO ALGUMA EQUIPAMENTO (ALARME,SOM,ETC)PERGUNTE AO CLIENTE COMO COMEÇOU E QDO ?
BOA SORTE
