4Digite no google dtc 2303, la vc encontrará um link (onde diz motor 1.6 flex) que te dará o caminho para concerto, mas este código refere-se a bobina de ignição e seu circuito.
http://www.svtlightnings.com/scantool/ford%20dtc%20codes.htm
Ford DTC codes
Codes from PCM - ODBII system -
Often Related to Check Engine or Service engine soon light
P0100 Mass Air Flow Circuit Malfunction
P0101 Mass Air Flow Circuit Range/Performance Problem
P0102 MAF Circuit Low Input
P0103 MAF Circuit High Input
P0104 MAF Circuit Intermittent
P0105 MAP/BP Circuit Malfunction
P0106 MAP/BP Sensor Range/Performance Problem
P0107 MAP/BP Sensor Low Input
P0108 MAP/BP Sensor High Input
P0109 MAP/BP Circuit Intermittent
P0110 IAT Circuit Malfunction
P0111 IAT Circuit Range/Performance Problem
P0112 IAT Circuit Low Input
P0113 IAT Circuit High Input
P0114 IAT Circuit Intermittent
P0115 ECT Circuit Malfunction
P0116 ECT Circuit Range/Performance Problem
P0117 ECT Circuit Low Input
P0118 ECT Circuit High Input
P0119 ECT Intermittent
P0120 TP Sensor A Circuit Malfunction
P0121 TP Sensor A Circuit Range/Performance Problem
P0122 TP Sensor A Circuit Low Input
P0123 TP Sensor A Circuit High Input
P0124 TP Sensor A Circuit Intermittent
P0125 Insufficient Coolant Temp For Closed Loop Fuel Control
P0126 Insufficient Coolant Temp For Stable Operation
P0128 Coolant Thermostat Malfunction
P0130 Heated O2 Sensor Circuit Malfunction (Bank 1, Sensor 1)
P0131 Heated O2 Circuit Low Voltage (Bank 1, Sensor 1)
P0132 Heated O2 Sensor Circuit High Voltage (Bank 1, Sensor 1)
P0133 Heated O2 Sensor Circuit Slow Response (Bank 1, Sensor 1)
P0134 Heated O2 Sensor Circuit No Activity Detected (Bank 1, Sensor 1)
P0135 Heated O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1)
P0136 Heated O2 Sensor Circuit Malfunction (Bank 1, Sensor 2)
P0137 Heated O2 Sensor Circuit Low Voltage (Bank 1, Sensor 2)
P0138 Heated O2 Sensor Circuit High Voltage (Bank 1, Sensor 2)
P0139 Heated O2 Sensor Circuit Slow Response (Bank 1, Sensor 2)
P0140 Heated O2 Sensor Circuit No Activity Detected (Bank 1, Sensor 2)
P0141 Heated O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 2)
P0142 Heated O2 Sensor Circuit Malfunction (Bank 1, Sensor 3)
P0143 Heated O2 Sensor Circuit Low Voltage (Bank 1, Sensor 3)
P0144 Heated O2 Sensor Circuit High Voltage (Bank 1, Sensor 3)
P0145 Heated O2 Sensor Circuit Slow Response (Bank 1, Sensor 3)
P0146 Heated O2 Sensor Circuit No Activity Detected (Bank 1, Sensor 3)
P0147 Heated O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 3)
P0150 Heated O2 Sensor Circuit Malfunction (Bank 2, Sensor 1)
P0151 Heated O2 Sensor Circuit Low Voltage (Bank 2, Sensor 1)
P0152 Heated O2 Sensor Circuit High Voltage (Bank 2, Sensor 1)
P0153 Heated O2 Sensor Circuit Slow Response (Bank 2, Sensor 1)
P0154 Heated O2 Sensor Circuit No Activity Detected (Bank 2, Sensor 1)
P0155 Heated O2 Sensor Heater Circuit Malfunction (Bank 2, Sensor 1)
P0156 Heated O2 Sensor Circuit Malfunction (Bank 2, Sensor 1)
P0157 Heated O2 Sensor Circuit Low Voltage (Bank 2, Sensor 2)
P0158 Heated O2 Sensor Circuit High Voltage (Bank 2, Sensor 2)
P0159 Heated O2 Sensor Circuit Slow Response (Bank 2, Sensor 2)
P0160 Heated O2 Sensor Circuit No Activity Detected (Bank 2, Sensor 2)
P0161 Heated O2 Sensor Heater Circuit Malfunction (Bank 2, Sensor 2)
P0170 Fuel Trim Malfunction (Bank 1)
P0171 System Too Lean (Bank 1)
P0172 System Too Rich (Bank 1)
P0173 Fuel Trim Malfunction (Bank 2)
P0174 System Too Lean (Bank 2)
P0175 System Too Rich (Bank 2)
P0176 Fuel Composition Sensor Circuit Fault
P0177 Fuel Composition Sensor Circuit Range/Performance
P0178 Fuel Composition Sensor Circuit Low Input
P0179 Fuel Composition Sensor Circuit High Input
P0180 Fuel Temperature Sensor A Circuit Malfunction
P0181 Fuel Temperature Sensor A Circuit Range/Performance
P0182 Fuel Temperature Sensor A Circuit Low Input
P0183 Fuel Temperature Sensor A Circuit High Input
P0184 Fuel Temperature Sensor A Circuit Intermittent
P0185 Fuel Temperature Sensor B Circuit Malfunction
P0186 Fuel Temperature Sensor B Circuit Range/Performance
P0187 Fuel Temperature Sensor B Circuit Low Input
P0188 Fuel Temperature Sensor B Circuit High Input
P0189 Fuel Temperature Sensor B Circuit Intermittent
P0190 Fuel Rail Pressure Sensor Circuit Malfunction
P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
P0192 Fuel Rail Pressure Sensor Circuit Low Input
P0193 Fuel Rail Pressure Sensor Circuit High Input
P0195 Engine Oil Temperature Sensor Circuit Malfunction
P0196 Engine Oil Temperature Sensor Range/Performance
P0197 Engine Oil Temperature Sensor Low
P0198 Engine Oil Temperature Sensor High
P0199 Engine Oil Temperature Sensor Intermittent
P0200 Injector Circuit Malfunction
P0201 Injector Circuit Malfunction - Cylinder #1
P0202 Injector Circuit Malfunction - Cylinder #2
P0203 Injector Circuit Malfunction - Cylinder #3
P0204 Injector Circuit Malfunction - Cylinder #4
P0205 Injector Circuit Malfunction - Cylinder #5
P0206 Injector Circuit Malfunction - Cylinder #6
P0207 Injector Circuit Malfunction - Cylinder #7
P0208 Injector Circuit Malfunction - Cylinder #8
P0209 Injector Circuit Malfunction - Cylinder #9
P0210 Injector Circuit Malfunction - Cylinder #10
P0211 Injector Circuit Malfunction - Cylinder #11
P0212 Injector Circuit Malfunction - Cylinder #12
P0213 Cold Start Injector #1 Malfunction
P0214 Cold Start Injector #2 Malfunction
P0215 Engine Shutoff Solenoid Malfunction
P0216 Injection Timing Control Circuit Malfunction
P0217 Engine Overtemp Condition
P0218 Transmission Overtemp Condition
P0219 Engine Overspeed Condition
P0220 Throttle/Pedal Position Sensor/Switch B Circuit Malfunction
P0221 Throttle/Pedal Position Sensor/Switch B Performance Problem
P0222 Throttle Position Sensor B Circuit Low Input
P0223 Throttle Position Sensor B Circuit High Input
P0224 Throttle Position Sensor B Intermittent
P0225 Throttle Position Sensor C Circuit Malfunction
P0227 Throttle Position Sensor C Circuit Low Input
P0228 Throttle Position Sensor C Circuit High Input
P0229 Throttle Position Sensor C Intermittent
P0230 Fuel Pump Primary Circuit Malfunction
P0231 Fuel Pump Secondary Circuit Low
P0232 Fuel Pump Secondary Circuit High
P0233 Fuel Pump Secondary Circuit Intermittent
P0234 Engine Overboost Condition
P0235 Turbocharger Boost Sensor A Circuit Malfunction
P0236 Turbocharger Boost Sensor A Performance
P0237 Turbocharger Boost Sensor A Circuit Low
P0238 Turbocharger Boost Sensor A Circuit High
P0239 Turbocharger Boost Sensor B Circuit Malfunction
P0240 Turbocharger Boost Sensor B Circuit Range/Performance
P0241 Turbocharger Boost Sensor B Circuit Low
P0242 Turbocharger Boost Sensor B Circuit High
P0243 Wastegate Solenoid A Malfunction
P0244 Wastegate Solenoid A Range/Performance
P0245 Wastegate Solenoid A Low
P0246 Wastegate Solenoid A High
P0247 Wastegate Solenoid B Malfunction
P0248 Wastegate Solenoid B Range/Performance
P0249 Wastegate Solenoid B Low
P0250 Wastegate Solenoid B High
P0251 Injection Pump Fuel Metering Control A Malfunction
P0252 Injection Pump Fuel Metering Control A Range/Performance
P0253 Injection Pump Fuel Metering Control A Low
P0254 Injection Pump Fuel Metering Control A High
P0255 Injection Pump Fuel Metering Control A Intermittent
P0256 Injection Pump Fuel Metering Control B Malfunction
P0257 Injection Pump Fuel Metering Control B Range/Performance
P0258 Injection Pump Fuel Metering Control B Low
P0259 Injection Pump Fuel Metering Control B High
P0260 Injection Pump Fuel Metering Control B Intermittent
P0261 Injector Circuit Low - Cylinder #1
P0262 Injector Circuit High - Cylinder #1
P0263 Cylinder #1 Balance Fault
P0264 Injector Circuit Low - Cylinder #2
P0265 Injector Circuit High - Cylinder #2
P0266 Cylinder #2 Balance Fault
P0267 Injector Circuit Low - Cylinder #3
P0268 Injector Circuit High - Cylinder #3
P0269 Cylinder #3 Balance Fault
P0270 Injector Circuit Low - Cylinder #4
P0271 Injector Circuit High - Cylinder #4
P0272 Cylinder #4 Balance Fault
P0273 Injector Circuit Low - Cylinder #5
P0274 Injector Circuit High - Cylinder #5
P0275 Cylinder #5 Balance Fault
P0276 Injector Circuit Low - Cylinder #6
P0277 Injector Circuit High - Cylinder #6
P0278 Cylinder #6 Balance Fault
P0279 Injector Circuit Low - Cylinder #7
P0280 Injector Circuit High - Cylinder #7
P0281 Cylinder #7 Balance Fault
P0282 Injector Circuit Low - Cylinder #8
P0283 Injector Circuit High - Cylinder #8
P0284 Cylinder #8 Balance Fault
P0285 Injector Circuit Low - Cylinder #9
P0286 Injector Circuit High - Cylinder #9
P0287 Cylinder #9 Balance Fault
P0288 Injector Circuit Low - Cylinder #10
P0289 Injector Circuit High - Cylinder #10
P0290 Cylinder #10 Balance Fault
P0291 Injector Circuit Low - Cylinder #11
P0292 Injector Circuit High - Cylinder #11
P0293 Cylinder #11 Balance Fault
P0294 Injector Circuit Low - Cylinder #12
P0295 Injector Circuit High - Cylinder #12
P0296 Cylinder #12 Balance Fault
P0300 Random Misfire Detected
P0301 Cylinder #1 Misfire Detected
P0302 Cylinder #2 Misfire Detected
P0303 Cylinder #3 Misfire Detected
P0304 Cylinder #4 Misfire Detected
P0305 Cylinder #5 Misfire Detected
P0306 Cylinder #6 Misfire Detected
P0307 Cylinder #7 Misfire Detected
P0308 Cylinder #8 Misfire Detected
P0309 Cylinder #9 Misfire Detected
P0310 Cylinder #10 Misfire Detected
P0311 Cylinder #11 Misfire Detected
P0312 Cylinder #12 Misfire Detected
P0320 Ignition Engine Speed Input Circuit Malfunction
P0321 Ignition Engine Speed Input Circuit Range/Performance
P0322 Ignition Engine Speed Input Circuit No Signal
P0323 Ignition Engine Speed Input Circuit Intermittent
P0325 Knock Sensor 1 Circuit Malfunction
P0326 Knock Sensor 1 Circuit Range/Performance
P0327 Knock Sensor 1 Circuit Low Input
P0328 Knock Sensor 1 Circuit High Input
P0329 Knock Sensor 1 Circuit Intermittent
P0330 Knock Sensor 2 Circuit Malfunction
P0331 Knock Sensor 2 Circuit Range/Performance
P0332 Knock Sensor 2 Circuit Low Input
P0333 Knock Sensor 2 Circuit High Input
P0334 Knock Sensor 2 Circuit Intermittent
P0335 Crankshaft Position Sensor A Circuit Malfunction
P0336 Crankshaft Position Sensor A Circuit Range/Performance
P0337 Crankshaft Position Sensor A Circuit Low Input
P0338 Crankshaft Position Sensor A Circuit High Input
P0339 Crankshaft Position Sensor A Circuit Intermittent
P0340 Camshaft Position Sensor Circuit Malfunction
P0341 Camshaft Position Sensor Circuit Performance
P0342 Camshaft Position Sensor Circuit Low Input
P0343 Camshaft Position Sensor Circuit High Input
P0344 Camshaft Position Sensor Circuit Intermittent
P0350 Ignition Coil Primary / Secondary Circuit Malfunction
P0351 Ignition Coil Primary A / Secondary Circuit Malfunction
P0352 Ignition Coil Primary B / Secondary Circuit Malfunction
P0353 Ignition Coil Primary C / Secondary Circuit Malfunction
P0354 Ignition Coil Primary D / Secondary Circuit Malfunction
P0355 Ignition Coil Primary E / Secondary Circuit Malfunction
P0356 Ignition Coil Primary F / Secondary Circuit Malfunction
P0357 Ignition Coil Primary G / Secondary Circuit Malfunction
P0358 Ignition Coil Primary H / Secondary Circuit Malfunction
P0359 Ignition Coil Primary I / Secondary Circuit Malfunction
P0360 Ignition Coil Primary J / Secondary Circuit Malfunction
P0361 Ignition Coil Primary K / Secondary Circuit Malfunction
P0362 Ignition Coil Primary L / Secondary Circuit Malfunction
P0370 Timing Reference High Resolution Signal A Malfunction
P0371 Timing Reference High Resolution Signal A Too Many Pulses
P0372 Timing Reference High Resolution Signal A Too Few Pulses
P0373 Timing Reference High Resolution Signal A Intermittent
P0374 Timing Reference High Resolution Signal A No Pulses
P0375 Timing Reference High Resolution Signal B Malfunction
P0376 Timing Reference High Resolution Signal B Too Many Pulses
P0377 Timing Reference High Resolution Signal B Too Few Pulses
P0378 Timing Reference High Resolution Signal B Intermittent
P0379 Timing Reference High Resolution Signal B No Pulses
P0380 Glow Plug Circuit A Malfunction
P0381 Glow Plug Indicator Circuit Malfunction
P0382 Glow Plug Circuit B Malfunction
P0385 Crankshaft Position Sensor B Circuit Malfunction
P0386 Crankshaft Position Sensor B Circuit Range/Performance
P0387 Crankshaft Position Sensor B Circuit Low Input
P0388 Crankshaft Position Sensor B Circuit High Input
P0389 Crankshaft Position Sensor B Circuit Intermittent
P0400 EGR Flow Malfunction
P0401 EGR Flow Insufficient Detected
P0402 EGR Flow Excessive Detected
P0403 EGR Circuit Malfunction
P0404 EGR Circuit Range/Performance
P0405 EGR Sensor A Circuit Low Input
P0406 EGR Sensor A Circuit High Input
P0407 EGR Sensor B Circuit Low Input
P0408 EGR Sensor B Circuit High Input
P0410 SAI System Malfunction
P0411 SAI System Incorrect Upstream Flow Detected
P0412 SAI System Switching Valve A Circuit Malfunction
P0413 SAI System Switching Valve A Circuit Open
P0414 SAI System Switching Valve A Circuit Shorted
P0415 SAI System Switching Valve B Circuit Malfunction
P0416 SAI System Switching Valve B Circuit Open
P0417 SAI System Switching Valve B Circuit Shorted
P0418 SAI System Relay A Circuit Malfunction
P0419 SAI System Relay B Circuit Malfunction
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)
P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
P0426 Catalyst Temperature Sensor Range/Performance (Bank 1)
P0427 Catalyst Temperature Sensor Low Input (Bank 1)
P0428 Catalyst Temperature Sensor High Input (Bank 1)
P0430 Catalyst System Efficiency Below Threshold (Bank 2)
P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)
P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
P0436 Catalyst Temperature Sensor Range/Performance (Bank 2)
P0437 Catalyst Temperature Sensor Low Input (Bank 2)
P0438 Catalyst Temperature Sensor High Input (Bank 2)
P0440 Evaporative Emission Control System Malfunction
P0441 Evaporative Emission Control System Incorrect Purge Flow
P0442 Evaporative Emission Control System Leak Detected
P0443 Evap Emission Control System Purge Control Circuit Malf.
P0444 Evap Emission Control Sys Purge Control Valve Circuit Open
P0445 Evap Emission Control Sys Purge Control Valve Circuit Short
P0446 Evap Emission Control System Vent Malfunction
P0447 Evap Emission Control System Vent Circuit Open
P0448 Evap Emission Control System Vent Circuit Shorted
P0449 Evap Emission Control System Vent Circuit Intermittent
P0450 Evap Emission Control System Pressure Sensor Malfunction
P0451 Evap Emission Control System Pressure Sensor Performance
P0452 Evap Emission Control System Pressure Sensor Low Input
P0453 Evap Emission Control System Pressure Sensor High Input
P0454 Evap Emission Control System Pressure Sensor Intermittent
P0455 Evap Emission Control System Leak Detected (Gross Leak/No Flow)
P0460 Fuel Level Sensor Circuit Malfunction
P0461 Fuel Level Sensor Circuit Range/Performance
P0462 Fuel Level Sensor Circuit Low Input
P0463 Fuel Level Sensor Circuit High Input
P0464 Fuel Level Sensor Circuit Intermittent
P0465 Purge Flow Sensor Circuit Malfunction
P0466 Purge Flow Sensor Circuit Range/Performance
P0467 Purge Flow Sensor Circuit Low Input
P0468 Purge Flow Sensor Circuit High Input
P0469 Purge Flow Sensor Circuit Intermittent
P0470 Exhaust Pressure Sensor Circuit Malfunction
P0471 Exhaust Pressure Sensor Circuit Range/Performance
P0472 Exhaust Pressure Sensor Low
P0473 Exhaust Pressure Sensor High
P0474 Exhaust Pressure Sensor Intermittent
P0475 Exhaust Pressure Control Valve Malfunction
P0476 Exhaust Pressure Control Valve Performance
P0477 Exhaust Pressure Control Valve Low
P0478 Exhaust Pressure Control Valve High
P0479 Exhaust Pressure Control Valve Intermittent
P0480 Cooling Fan 1 Control Circuit Malfunction
P0481 Cooling Fan 2 Control Circuit Malfunction
P0482 Cooling Fan 3 Control Circuit Malfunction
P0483 Cooling Fan Rationality Check Malfunction
P0484 Cooling Fan Circuit Over Current
P0485 Cooling Fan Power/Ground Circuit Malfunction
P0500 Vehicle Speed Sensor Malfunction
P0501 Vehicle Speed Sensor Range/Performance
P0502 Vehicle Speed Sensor Low Input
P0503 Vehicle Speed Sensor Intermittent
P0505 Idle Air Control System Malfunction
P0506 Idle Air Control System RPM Lower Than Expected
P0507 Idle Air Control System RPM Higher Than Expected
P0510 Closed Throttle Position Switch Malfunction
P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction
P0521 Engine Oil Pressure Sensor/Switch Circuit Range/Performance
P0522 Engine Oil Pressure Sensor/Switch Circuit Low Input
P0523 Engine Oil Pressure Sensor/Switch Circuit High Input
P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
P0532 A/C Refrigerant Pressure Sensor Circuit Low Input
P0533 A/C Refrigerant Pressure Sensor Circuit High Input
P0534 A/C Refrigerant Charge Loss
P0550 Power Steering Pressure Sensor Circuit Malfunction
P0551 Power Steering Pressure Sensor Circuit Range/Performance
P0552 Power Steering Pressure Sensor Circuit Low Input
P0553 Power Steering Pressure Sensor Circuit High Input
P0554 Power Steering Pressure Sensor Circuit Intermittent
P0560 System Voltage Malfunction
P0561 System Voltage Unstable
P0562 System Voltage Low
P0563 System Voltage High
P0565 Cruise ON Signal Malfunction
P0566 Cruise OFF Signal Malfunction
P0567 Cruise RESUME Signal Malfunction
P0568 Cruise SET Signal Malfunction
P0569 Cruise COAST Signal Malfunction
P0570 Cruise ACCEL Signal Malfunction
P0571 Cruise Brake Switch Circuit Malfunction
P0572 Cruise Brake Switch Circuit Low
P0573 Cruise Brake Switch Circuit High
P0600 Serial Communications Link Malfunction
P0601 Internal Control Module Memory Check Sum Error
P0602 Control Module Programming Error
P0603 Powertrain Control Module KAM Test Error
P0604 Powertrain Control Module RAM Test Error
P0605 Powertrain Control Module ROM Test Error
P0606 PCM Processor Fault
P0608 PCM VSS Output A Malfunction
P0609 PCM VSS Output B Malfunction
P0620 Generator Control Circuit Malfunction
P0621 Generator Lamp "L" Control Circuit Malfunction
P0622 Generator Field "F" Control Circuit Malfunction
P0650 MIL Control Circuit Malfunction
P0700 Transmission Control System Malfunction
P0701 Transmission Control System Range/Performance
P0702 Transmission Control System Electrical
P0703 Brake Switch Input Malfunction
P0704 Clutch Switch Input Circuit Malfunction
P0705 Transmission Range Sensor Circuit Malfunction
P0706 Transmission Range Sensor Circuit Range/Performance
P0707 Transmission Range Sensor Circuit Low Input
P0708 Transmission Range Sensor Circuit High Input
P0709 Transmission Range Sensor Circuit Intermittent
P0710 Transmission Fluid Temperature Sensor Circuit Malfunction
P0711 Transmission Fluid Temperature Sensor Circuit Range/Perf
P0712 Transmission Fluid Temp Sensor Circuit Low Input
P0713 Transmission Fluid Temp Sensor Circuit High Input
P0714 Transmission Fluid Temp Sensor Circuit Intermittent
P0715 Turbine Speed Sensor Circuit Malfunction
P0716 Turbine Speed Sensor Circuit Range/Performance
P0717 Turbine Speed Sensor Circuit No Signal
P0718 Turbine Speed Sensor Circuit Intermittent
P0719 Torque Converter/Brake Switch B Circuit Low
P0720 Output Shaft Speed Sensor Circuit Malfunction
P0721 Output Shaft Speed Sensor No Performance
P0722 Output Shaft Speed Sensor No Signal
P0723 Output Shaft Speed Sensor Intermittent
P0724 Torque Converter/Brake Switch B Circuit High
P0725 Engine Speed Input Circuit Malfunction
P0726 Engine Speed Input Circuit Range/Performance
P0727 Engine Speed Input Circuit No Signal
P0728 Engine Speed Input Circuit Intermittent
P0730 Incorrect Gear Ratio
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0735 Gear 5 Incorrect Ratio
P0736 Reverse Incorrect Ratio
P0740 Torque Converter Clutch Circuit Malfunction
P0741 Torque Converter Clutch System Performance Or Stuck Off
P0742 Torque Converter Clutch Circuit Stuck On
P0743 Torque Converter Clutch System Electrical
P0744 Torque Converter Clutch Circuit Intermittent
P0745 Pressure Control Solenoid A Malfunction
P0746 Pressure Control Solenoid A Performance or Stuck Off
P0747 Pressure Control Solenoid A Stuck On
P0748 Pressure Control Solenoid A Electrical
P0749 Pressure Control Solenoid A Intermittent
P0750 Shift Solenoid A Malfunction
P0751 Shift Solenoid A Performance
P0752 Shift Solenoid A Stuck On
P0753 Shift Solenoid A Electrical
P0754 Shift Solenoid A Intermittent
P0755 Shift Solenoid B Malfunction
P0756 Shift Solenoid B Performance
P0757 Shift Solenoid B Stuck On
P0758 Shift Solenoid B Electrical
P0759 Shift Solenoid B Intermittent
P0760 Shift Solenoid C Malfunction
P0761 Shift Solenoid C Performance
P0762 Shift Solenoid C Stuck On
P0763 Shift Solenoid C Electrical
P0764 Shift Solenoid C Intermittent
P0765 Shift Solenoid D Malfunction
P0766 Shift Solenoid D Performance
P0767 Shift Solenoid D Stuck On
P0768 Shift Solenoid D Electrical
P0769 Shift Solenoid D Intermittent
P0770 Shift Solenoid E Malfunction
P0771 Shift Solenoid E Performance
P0772 Shift Solenoid E Stuck On
P0773 Shift Solenoid E Electrical
P0774 Shift Solenoid E Intermittent
P0775 Pressure Control Solenoid B Malfunction
P0776 Pressure Control Solenoid B Performance
P0777 Pressure Control Solenoid B Stuck On
P0778 Pressure Control Solenoid B Electrical
P0779 Pressure Control Solenoid B Intermittent
P0780 Shift Malfunction
P0781 1 - 2 Shift Error
P0782 2 - 3 Shift Error
P0783 3 - 4 Shift Error
P0784 4 - 5 Shift Error
P0785 Shift/Timing Solenoid Malfunction
P0786 Shift/Timing Solenoid Range/Performance
P0787 Shift/Timing Solenoid Low
P0788 Shift/Timing Solenoid High
P0789 Shift/Timing Solenoid Intermittent
P0790 Mode Switch Circuit Malfunction
P0801 Reverse Inhibit Control Circuit Malfunction
P0803 1 - 4 Upshift (Skip Shift) Solenoid Circuit Malfunction
P0804 1 - 4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
P1000 Check of all OBDII Systems Not Complete
P1001 KOER Not Able To Complete. KOER Aborted.
P1100 MAF Sensor Intermittent
P1101 MAF Sensor Out Of Self Test Range
P1102 MAF Sensor In Range But Lower Than Expected
P1103 MAF Sensor In Range But Higher Than Expected
P1104 MAF Ground Malfunction
P1105 Dual Alternator Upper Fault
P1106 Dual Alternator Lower Fault
P1107 Dual Alternator Lower Circuit Malfunction
P1108 Dual Alternator Battery Lamp Circuit Malfunction
P1109 IAT - B Sensor Intermittent
P1110 IAT Sensor (D/C) Open/Short
P1111 System Pass
P1112 IAT Sensor Intermittent
P1113 IAT Sensor (L/C) Open/Short
P1114 IAT - B Circuit Low Input
P1115 IAT - B Circuit High Input
P1116 ECT Sensor Out Of Self Test Range
P1117 ECT Sensor Intermittent
P1118 Manifold Absolute Temperature Circuit Low Input
P1119 Manifold Absolute Temperature Circuit High Input
P1120 TP Sensor Out Of Range Low (Ratch Too Low)
P1121 TP Sensor Inconsistent With MAF Sensor
P1122 TP In Range But Lower Than Expected
P1123 TP In Range But Higher Than Expected
P1124 TP Sensor Out Of Self Test Range
P1125 TP Sensor Intermittent
P1126 TP (Narrow Range) Sensor Circuit Malfunction
P1127 Exhaust Not Warm, Downstream O2 Sensor Not Tester
P1128 Upstream Heated O2 Sensors Swapped
P1129 Downstream Heated O2 Sensors Swapped
P1130 Lack Of HO2S11 Switch - Adaptive Fuel At Limit
P1131 Lack Of HO2S11 Switch - Sensor Indicates Lean
P1132 Lack Of HO2S11 Switch - Sensor Indicates Rich
P1133 Bank 1 Fuel Control Shifted Lean (FAOSC)
P1134 Bank 1 Fuel Control Shifted Rich (FAOSC)
P1135 Pedal Position Sensor A Circuit Intermittent
P1136 Control Box Fan Circuit Malfunction
P1137 Lack Of HO2S12 Switch - Sensor Indicates Lean
P1138 Lack Of HO2S12 Switch - Sensor Indicates Rich
P1139 Water In Fuel Indicator Circuit Malfunction
P1140 Water In Fuel Condition
P1141 Fuel Restriction Indicator Circuit Malfunction
P1142 Fuel Restriction Condition
P1143 Air Assist Control Valve Range/Performance
P1144 Air Assist Control Valve Circuit Malfunction
P1150 Lack Of HO2S21 Switch - Adaptive Fuel At Limit
P1151 Lack Of HO2S21 Switch - Sensor Indicates Lean
P1152 Lack Of HO2S21 Switch - Sensor Indicates Rich
P1153 Bank 2 Fuel Control Shifted Lean (FAOSC)
P1154 Bank 2 Fuel Control Shifted Rich (FAOSC)
P1155 Alternative Fuel Controller Has Activated the MIL
P1156 Fuel Select Switch Malfunction
P1157 Lack Of HO2S22 Switch - Sensor Indicates Lean
P1158 Lack Of HO2S22 Switch - Sensor Indicates Rich
P1159 Fuel Stepper Motor Malfunction
P1167 Invalid Test, Operator Did Not Actuate Throttle
P1168 Fuel Rail Sensor In-Range Low Failure
P1169 Fuel Rail Sensor In-Range High Failure
P1170 ESO - Engine Shut Off Solenoid Fault
P1171 Rotor Sensor Fault
P1172 Rotor Control Fault
P1173 Rotor Calibration Fault
P1174 Cam Sensor Fault
P1175 Cam Control Fault
P1176 Cam Calibration Fault
P1177 Synchronisation Fault
P1178 Boltup Limits Fault
P1180 Fuel Delivery System Malfunction - Low
P1181 Fuel Delivery System Malfunction - High
P1182 Fuel Shut Off Solenoid Malfunction
P1183 Engine Oil Temperature Circuit Malfunction
P1184 Engine Oil Temperature Out Of Self Test Range
P1185 FTS High - Fuel Pump Temperature Sensor High
P1186 FTS Low - Fuel Pump Temperature Sensor Low
P1187 Variant Selection
P1188 Calibration Memory Fault
P1189 Pump Speed Signal Fault
P1190 Calibration Resistor Out Of Range
P1191 Key Line Voltage
P1192 V External
P1193 EGR Drive Overcurrent
P1194 ECU A/D Converter
P1195 SCP HBCC Failed To Initialize
P1196 Key Off Voltage High
P1197 Key Off Voltage Low
P1198 Pump Rotor Control Underfueling
P1199 Fuel Level Input Circuit Low
P1201 Injector Circuit Open / Shorted - Cylinder #1
P1202 Injector Circuit Open / Shorted - Cylinder #2
P1203 Injector Circuit Open / Shorted - Cylinder #3
P1204 Injector Circuit Open / Shorted - Cylinder #4
P1205 Injector Circuit Open / Shorted - Cylinder #5
P1206 Injector Circuit Open / Shorted - Cylinder #6
P1209 Injector Control Pressure System Fault
P1210 Injector Control Pressure Above Expected Level
P1211 Injector Control Pressure Sensor Above / Below Desired
P1212 Injector Control Pressure Not Detected During Crank
P1213 Start Injector Circuit Malfunction
P1214 Pedal Position Sensor B Circuit Intermittent
P1215 Pedal Position Sensor C Circuit Low Input
P1216 Pedal Position Sensor C Circuit High Input
P1217 Pedal Position Sensor C Circuit Intermittent
P1218 CID High
P1219 CID Low
P1220 Series Throttle Control System Malfunction
P1221 Traction Control System Malfunction
P1222 Traction Control Output Circuit Malfunction
P1223 Pedal Demand Sensor B Circuit High Input
P1224 Throttle Position Sensor B Out Of Self Test Range
P1225 Needle Lift Sensor Malfunction
P1226 Control Sleeve Sensor Malfunction
P1227 Wastegate Failed Closed (Over Pressure)
P1228 Wastegate Failed Open (Under Pressure)
P1229 Intercooler Pump Driver Fault
P1230 Fuel Pump Low Speed Malfunction
P1231 Fuel Pump Secondary Circuit Low, High Speed
P1232 Fuel Pump Speed Primary Circuit Malfunction
P1233 Fuel Pump Driver Module Off Line
P1234 Fuel Pump Driver Module Off Line
P1235 Fuel Pump Control Out Of Range
P1236 Fuel Pump Control Out Of Range
P1237 Fuel Pump Secondary Circuit Malfunction
P1238 Fuel Pump Secondary Circuit Malfunction
P1239 Speed Fuel Pump Positive Feed Fault
P1240 Sensor Power Supply Malfunction
P1241 Sensor Power Supply Low Input
P1242 Sensor Power Supply High Input
P1243 Second Fuel Pump Faulty or Ground Fault
P1244 Alternator Load Input Failed High
P1245 Alternator Load Input Failed Low
P1246 Alternator Load Input Failed
P1247 Turbo Boost Pressure Low
P1248 Turbo Boost Pressure Not Detected
P1249 Wastegate Control Valve Performance
P1250 PRC Solenoid Circuit Malfunction
P1251 Air Mixture Solenoid Circuit Malfunction
P1252 Pedal Correlation PDS1 and LPDS High
P1253 Pedal Correlation PDS1 and LPDS Low
P1254 Pedal Correlation PDS2 and LPDS High
P1255
obrigado
Get the Best Cheap Blog Commenting Service in the Market...
